SF2 Turbo & Bloodstorm: No image, No boot
WolfManCat
Donor 3 years: 2017, 2019, 2022
Graham, Washington
Hi I have two games with similar problems.
First I have a Blood Storm in a strata cab that one day just stopped working. Gameboard and monitor do not turn on. I swapped the psu and it has a lit status light, but I can't even get it to play blind. Just a marquee and coin door lights.
Second I have a Street Fighter 2 turbo in a Z back which had a large diode burnout on the monitor chassis. I swapped the monitor, but again just like on Bloodstorm I can't even get it to play blind now.
Not sure where I should start troubleshooting on these. Possibly somebody could point me in the right direction?
Thanks in advance.
You swapped power supplies but did you check the power it was putting out? Sounds like a loose connection or a fuse maybe?
