SF2 Pin NO POWER AT ALL!! GRRRRRR
wmacmonagle
Donor 2012
Rosamond, California
I had traded some of my arcades for one PIN and it was very dusty and rubbers cracked all over. We tested at my home and it powers up and i tested to play and it works!!! rotary works .. everything s all working!! im thrilled and traded.
i decide to power off and unplug. removes the glass and did the major cleaning and replaced the rubbers!!! with lifting up and down the playfield several of times. after finishing the replacing the rubbers.
i plug in and turn on . NOTHING respond. I m like what? checked the power surcharge and hoped it s off . NOPE it is ON! im like.. moved plug to other and NOTHING.. not even one LED light on. it s like DEAD!!!!! not even backbox light. DEAD. im like.. checking the AC box 2 fuses and looks ok. Checked the middle bottom box and there is total of 6 or 7 fuses and looks OK.
what else to look. I checked back box and there is no FUSES or any thing.
i dont want to flip it over while there were only one thing i need to plug!.
thanks for the help!
I already thought of that and still no luck. I dont even see any led. I do have dmm so should i test on fuses to see any powers on power supply in the middle. If i dont get any voltages then whats next to target. Wmac
Start by checking for AC voltage coming in, then go from there. If it worked fine and now you have nothing, it is either the power switch or the interlock switches that ken had mentioned.
