SF Rush - manual transmission issues
Grbgemen
Lincoln, Nebraska
When I select the manual transmission and start a race, the vehicle accelerates and starts to redline. When you switch to 2nd, it starts to redline again. Same with 3rd and 4th gear. Can only get up to 60mph or so.
Automatic transmission works just fine. I reset all the limits in the test screen and All gear switches activate just fine.
This a board issue or a pot issue?
I think your clutch is going bad :-(
Now that I think about it...I was joking...but if it does have a clutch pedal, check the pot on it for creep.
I myself just got a rush, and Im curious as to where the steering pot is located? I know I need to fix the force feedback (it pulls all the way to the right) but I wanted to check out the steering pot just to make sure it is fine.
Where was your bad 5k pot located? I don't really see any ajustable pots in the back of the cab anywhere.
Thanks!
