VectorJunkie
Anyone know a good source for classic (read old) seven segment displays? I have a Cocktail pinball machine (Roy Clark) that has an older style of digit. Three of the digits have bad segments. I checked all the big electronics supply places and they even have the same style, same pin layout, and same size. The problem is they don't have one display with all the attributes.
I have checked some of the places that have nixie tubes and other stuff online, but have not found a big source for the old LED displays other than ebay. I also went through every new LED display manufacturer I could find to look at their spec sheets with no luck along with some pinball parts houses.
If anyone has any lying around the style is like this.
I need .50" height digits with the pins along the top and bottom. I suspect I may have to update all the digits to a new style unless I can find an old display board to rob some from. Thanks for any help you can provide.
-VJ
-VJ
