Drkirby
I have just been able to get two untested Arkanoid boards cheaply, though upon inspection, I have just noticed that they don't use a normal Jamma Harness. While I see I can buy something for $50, I would much rather try to wire it up my self to save a few dollars. Anyone know what parts would be good for this? I am guessing a 44 pin edge connector, but what would could I use for the second set of pin, that are used for the power? And is there any sort of double sided 56 pin slot I could use to solder the wires from the two harnesses to, and just plug into my current Jamma harness? And where would be a good place to buy all of this?
Also, while it may not be the best way to play, would there be any problems trying to control the game using a joystick, so I can test the two boards?
I'll attach a picture of one of the boards if needed for reference. Also, the main site has a copy of the manual here: http://www.arcade-museum.com/manuals-videogames/A/arkanoid.pdf
Thanks for the help
Thanks for the help
