Service switch on Sanyo Ez20 -
Hoody
Meridian, Idaho
What does this switch do?
Is it for cor adjustment?
When I switch it I get a solid vertical line running down the middle. I have some monitor issues I'm working thru and curious what it's used for.
That is a test switch which turns off the vertical deflection and allows the white balance on the monitor to be adjusted. The goal is to adjust the RGB on the screen to make the line as white as possible.
