Sencore CR7000 Manual
jayleone
Donor 2015-2016
Providence, Rhode Island
Does anyone have a link to the Sencore CR7000 manual? I just purchased this rejuvenator, and it's missing the manual and all documentation :(
Thanks in advance!
I have a friend who just bought a CR7000 too. He's looking for the manual.
Sencore is like "Did we make that?" now. They've discontinued support for everything older than 5 years.
here is all the setup info. just create a login and it's all there
www.sencore-e.com
that works great but if you don't have access to it when or where your working that paper manual would be handy then. if anyone comes up with one i would be interested in buying a copy.
Not every setup is in the manual. I can access it with a smart phone when I'm out on a job.
My friend that needed the manual was able to purchase it from Sencore's parts department at the phone number I previously mentioned. He says it's on it's way.
i once wrote a script to leech all of the CR-31 setup data off if e-sencore, and reformatted into CSV, for use in almost any platform (on- or offline).
do you have that for the cr7000? how could that be done if not?
thanks
i do have a log in for sencore but when i called them last year they said they didn't have it in hard copy or a pdf.
Sencore still has hard copies of the owner's/users manuals. That's what my friend bought from their parts department. My friend got his copy a few days ago.
thanks
Does the 7000 use adapters? Or is it the one where you plug in each pin seperately.? If it's the latter, I do not have that, as it requires the pin out data. I only leeched the adapter, til voltage, bias, etc. settings.
Yes the 7000 uses adapters, but also came with a 'universal' adapter with the mini-grabber clips.
In that case, yes I can reproduce the process for the CR7000 set-up data on e-sencore.com
The process is pretty straightforward ;) ...
1) recognize the URL pattern used by the data pages on e-sencore.com
2) use Excel to create a URL list of all 700-odd pages of list data, export list to .txt. For example: http://sencore-e.com/crt/crts/getResults/page:1/analyzer:CR31
3) use wget to retrieve all of the HTML from each page in the URL list.
4) write a perl script to process those HTML files and output a CSV file with each of the data fields (CRT #, sockets, type, filament, bias, direct heat). For example: "A20JQW00X","X21","Video",6.3,"C","No",
Luckily, I still have all that from doing the CR31, so it should be fairly easy to re-use it for the CR7000 data.
OK, here's the CR7000 setup data from e-sencore.
I didn't clean it up (remove dupes, incomplete listings, etc.) like I did for the CR31 data.
It's a .csv (comma seperated values) table with 11,170 lines. The field titles are:
CRT#, adapter, type, filament voltage, bias, direct heat
Enjoy.
  • cr7000-list.zip
thanks ken i will call them when i get back home from my work trip.
I need to do some light maintenance on my cr7000. does anyone know if a repair manual or schematic exists for this?
DarrenF....thanks for putting the csv together. Very useful and saves time searching through that darn book.
pm me with your email and i will send you the cr7000 schematics
Enjoy.
Nice. Any chance you could throw the CR70 data through the same wringer?
Bumping an old thread, but come bearing a gift :)
I took DarrenF's zip file above, for the CR7000, and cleaned up the whole list. No dup's, most incomplete listings, ect.... I kept only the incomplete listings, that had the most of the useful information available. Thank you DarrenF.
I have this available in an Excel file, but it's too big to post as an attachment. If anyone is interested, just PM me with an email address, and I'll send it to ya. Only have it on one computer though, so you'll have to wait until I'm at that computer :D
