tester007
Bought a cr-70.. Was dead on arrival, so bought a second one... Man.. The 3 23" black and whites i had all tested good, but i did an auto restore on them and cannot believe the difference.
But have a question on the color setting. I have just checked a couple g07's and every monitor seems to be the same for color tracking. everything is good except for that. The manual says to do each gun one after another so the settings for all 3 are stored and compared. But it doesn't say how that is done really.
If i start with red. I have 3 other settings to switch to choose that gun ( the 3 numbers in the manual beside the crt number). The manual simply says to turn to the other two colors to do the test and to store the settings for each. Do you turn to green, then set the 3 numbers, then turn to blue, and set the 3 numbers?
Not sure if just turning the color dial is enough on its own withoit setting the 3 numbers, if it should be turned off, then on between colors...etc..or really how its done..
