Anybody have any ideas? Did you take a look at the pics I posted for anything weird?
1: What is this white cylinder? It's marked 1 2 3 4. One of the pins had no continuity to the next component on the trace due to crappy solder/pcb damage. This component looks like it's fed pretty directly from the AC in, so it would explain why no power is getting to the rest of the board, right?
2: Another picture of the weird modification to the degaussing circuit. This is mounted to the metal around the tube and does not detatch. I ended up cutting this circuit out of the loop entirely and have the degaussing coil running straight to the board now.
3: A picture of the yoke. These wires are NOT detatchable without cutting.
4: A picture of the modifications on the solder side of the main chassis. The red wires were there when I acquired the monitor.
I have no idea. can't tell from your pic, nor where it was attached.
modessitt said:That is the normal way a K4600 degauss circuit is wired. I'm not sure for the exact reason it is there, but it should be.
modessitt said:Normally they just unplug from the yoke. Pull on the red wire at the top of the yoke and see if it unplugs. the yoke is labeled R,Y,G,B to show where the colored wires plug in. Sometimes the R & B or G & Y positions are switched in order to flip the picture. I've seen people solder these directly when the connectors get loose and won't stay on.
modessitt said:So - leave them alone...
That's the plan, but I've been asking all along: are they 'normal' or if they are indicative of repair work? That's still the question.
Adjust what, the B+? I haven't attempted to adjust that. Does it need adjusting? Is it the pot on the little daughter board on the far left of the board?
The pot on the left daughtercard is for adjusting the screen control (brightness). Some will have two pots, and the 2nd is for the horizontal positioning.
No, I was referring to adjusting the horizontal hold pot on the right daughtercard to get your image better. It is in the center of the board, and usually missed:
http://therealbobroberts.net/slanted.html
