Segai 19" m21c13 monitor *stumped*
arcadejunke9
Permanently Banned
louisville, Kentucky
i have a question for everyone... has anyone dealt with these monitors? mine luckly will come on but when i try to hook it up to pacman it wont sync right, the screen is greenish and lines look like a osciliscope at times depending how you tune the pots, i cant seem to find a pinout of the monitor jack on the mainboard. its marked R G and B but i cant see the other stuff as it is missing, i paid 20$ for it untested and all but i can tune the color pots and get multiple colors... red, green, blue, yellow, magenta and so on... help plz???
Does it look like this?
thats the one.... um what would cause my syncing issue? plus the oscilliscope looking picture on the screen, uum i can plug ms.pac in and see the marquee logo on the attract screen only that its greenish and the dots and ghosts cant be made out.
Well, if yours is 100v and you are connecting 120v, that might be a problem. Otherwise, post a pic of your video connection....
ok i may have screwed up, its definatly a 100v monitor, uum i dont have a nintendo xformer to test it with as i know those are 100v stepdown transformers, how do i test it correctly? what do i buy? could any damage of been caused? btw my model is m21cxx
I told you yesterday....that's an early Happ (re-branded) Vision Pro monitor. Google is your friend...
http://arcarc.xmission.com/PDF_Monitors/Happ Controls SE-M21C XX 13 or 19.pdf
It's a switch mode powered monitor. That means it'll operate at 90VAC to 250VAC (give or take). Good old USA 120VAC won't hurt it. It's auto syncing (like I told you yesterday). The six pin input header is....red/green/blue/ground/horizontal sync/vertical sync. It auto syncs for negative or positive sync....for composite sync, use the horizontal input...like most monitors. You've probably got the sync wired wrong....and you stilll need to do a cap kit like I told you. That will probably get rid of the pulsing.
Happ/Segai SE-M21C K1-2-V0 19"
0.47uf50V C101/C102/C103
1uf50V C107/C108/C310/C311/C506
1uf160V C117/C118/C119
1uf250V C122/C219/C332/C334
4.7uf50V C314
10uf50V C218/C335
22uf25V C105/C110
33uf160V C120/C328
47uf16V C212
47uf35V C217/C324
47uf160V C327
100uf25V C104/C306/C329/C508
100uf35V C316
100uf160V C514/C515
220uf25V C208/C318
220uf35V C315
220uf400V C513 B+ Filter Cap
1000uf25V C526
1000uf35V C522
2200uf25V C213/C527
2200uf35V C523 105 degree Cap
And a 30 minute bump is ridiculous!
Edward
