Heh... no, unless you want to do a LOT of work. The monitor goes through fine, and the base that the monitor sits on also fits, if you tilt it on its side. But the skateboard base is 38" wide... and HEAVY. The only way I got it in my basement is by taking the rails and the coin/control panel section off. Then, the base was still ridiculously heavy, but it'd fit through the door, if you can tilt it on its side and carry it through. Definitely not a fun procedure. I almost considered installing french doors instead.
