Sega Super Hang On PCB in working order.
Jeff F
Donor 12 years: 2011-2022
Johnson City, New York
[edit]No longer needed...
Hoping someone just has one sitting around taking up space because... I'm *RRRRrrrreally* cheap! ;)
[edit]No longer looking...
What range does "not cheap" run? ;)
Just curious because all I have is a little graphic glitch that looks like it could be a bad RAM or two. If the board is high $$$ then I'll just suffer and/or try troubleshooting it.
I have all the guts pcb,ps,un cut wiring, ect. everything except cab and monitor.
What are you willing to give or trade.
PM'd you but never heard back...
At any rate, I no longer need one. Our graphic glitch really isn't too bad and I ended up getting a supposedly semi-working CPU PCB off eBay for $25 shipped. It sounds like this board has a similar problem to the one we have so I'll experiment on it and see if I can finger it out. :)
