Sega Star Wars Trilogy arcade joystick q (upright vs deluxe)
fmc819
Are the joysticks on the upright and deluxe the same/swappable?
No. They have nothing in common whatsoever.
UR is a Happ Analog with 2-5k pots. DX uses two Sega servomotors with optical position sensors.
Thanks good to know. Having a hard time finding replacement pots for the upright.
IIRC not all deluxe sit-down models are force feedback. I might be wrong but if you have a force feedback joystick then you need the force feedback with the servo motors and if you have a regular joystick then they are interchangeable.
I can look at my upright but if I remember correctly they are just a standard heavy duty metal body pot.
There is an adjustment board on the stick that (probably?) makes it so that you can use various value pots.
I might be wrong
No, you're actually not wrong. Sega also sold some 50" sit-down cabs with the big bench seat that fits 2 people that did use the same stick as the UR.
I think they were factory-converted Ocean Hunter cabs that didn't sell...
The "real" DX with the force-feedback stick has the small seat with the two pink fluorescent lamps mounted on the back of it.
