sega r/w card error and network error on intial d v3 machine
therealmogwai
mount hope, Ontario, Canada
Hey all...
i have an initial d stage 3 2 player machine and consistently have problems with it.
one of the two card readers always errors and fails to initialize and sometimes i get a network error. Does anyone have any experience with these machines?
card reader and network is separate problem.
both, they have their own test on test menu. you can test card reader in test menu, while the cart pulled out and see what kind of problem that make it stuck in error. also with network, you can see the test screen, and check for cables and network jack.
so i finished checking out the machine and here the results...
r/w error on the card 1 reader..not very specific... its such a pisser cause now i have purchased 4 different card readers and all seem to have died rather quickly
as for the network error, there is no network test within the test menu in initial d version 3. I know there is mention of in it intial d version 1, as it is mentioned in the instruction manual, but nothing to test the network connection within the test menu. That being said when you reassign the cabinet to machine 1 and 2 it does a mini test, which it passes...but the machine picture just goes black right after the network test screen when you turn the machine on!
any ideas?
