sega pins gotta luv em, field falls inside cab with prop stick up
r5g
Nevada
gotta luv sega pins
one dept seemed to have no idea what other engineering depts had done.
this theme repeats many times
heres a few
on a baywatch i go to prop the field up,
the inside field support rails are so thin that with the prop stick in the slot, the whole thing shifts to one side, then the rails are to thin to hold it up, and the entire field falls inside cab. omg.
no. 2. with the rear legs set to right height, for the field angle, the coin door wont work, angle too steep for coin mechs, they kick the coins back on any adjustment setting, solution : those black imonex mechs that have no moving parts and are molded are the only thing that will work with that coin door and its steep incorrect, non 90' angle
I won't even prop my field up with that garbage on South Park. I just grab a steel rod or broom stick or some such thing and wedge it in wherever the mood strikes me to do so. Supports a lot better and less scratching of the interior side paint.
