Sega Outrun Upright - Which Fuses Do I Need to Use?
9914ken
Parker, Colorado
Hey all, so Ive searched for the answer to this question and I would like to get a council of wisdom from you all.
I know the manual states to use the following in the fuse holder: 3A - 5A - 4A - 6A in this order from the front of the cab to the back. The one I have looks to have had the fuses replaced at some time. It came with 3A(AGC) - 4A(AGC) - 5A (the metal inside the fuse is braided-SLOW BLOW?) 3AG 32V (I know this definitely wrong)
Should the order and type be: 3A (SLOW BLOW) 5A (SLOW BLOW) 4A (SLOW BLOW) 6A (SLOW BLOW)
Any feedback here would be greatly appreciated.
OK, so I did some more digging and from everything that Ive read and understand, the slow-blow on the initial start-up is the way to go. It make sense that it would handle the initial start and build-up and then distribute.
