Hey guys I need some help hooking the oard back up on this upright OutRun. Some of the canles are easy to tell where they go but the othjers arnt. I looked at the manual but I need some help still. Thanks.
Well I kind of guessed at the hookup. Theres 2 wires on the bottom of the boards. Does it matter witch one hooks on each board? Also I plugged it up and the board lights come on and the monitor comes on, but theres like wave lines on it. It reminds me of when you turn a tv onthe wrong channeland those lines go through it.
The 2 connectors on the bottom of the board are power inputs and I think they're the same so it shouldn't matter which one goes to which board. Make sure the connector going from the board to the monitor is hooked up to the right spot on the board because it can be hooked up in two spots. I had mine hooked up wrong at first and had just a blue screen. I *think* the connector on the left side of the board is the correct one for video and not the one on the bottom.
Oh yeah sorry. There was a plug on the bottom corner of the board that I swithced the monitor wire to from the left side. I didnt have a clue it was down there.
