Sega Out Run: Roads look funny, other graphics and sound ok
john2654
Donor 3 years: 2011, 2020, 2024
Rhinelander, Wisconsin
I have a Sega Out Run board set. Everything appears to be working fine except the roads look funny. Did a chip go bad and not the whole board? If it is only a chip, which one should I try to replace. I have another board set that I can swap parts off of.
Thanks!
I had this problem with my T.Outrun not too long ago...It would pass all its Ram/Rom tests 100% and still had a road graphic problem. If your board passes all its tests and still has a problem...its in deep. Not that it cant be fixed..but most likely your going to have to send it out for repair...or buy another boardset...
Bought a board set on ebay - had problems with the CPU board. Swapped my video board with the ebay set and now it works 100%. OH YEAH!!! Anyone need a complete board set for parts??? CPU board has bad road/street chip and video board does not sync, otherwise works fine.
