Sega Nascar Arcade with Wells Gardner 9300 series monitor issue
irish2010
Carrollton, Texas
I have a Sega Nascar Arcade with Wells Gardner 9300 series monitor. Everything works great. When I got it I noticed the the screen was rolling top to bottom. After a while it stopped. Then I noticed that the monitor was blinking on and off every so often. Then one time it blink off and showed "No Signal" then came right back on. I played around with it looking for loose wires. No I have a issue with the H Size. The screen is only about 1.5" wide and it is still rolling top to bottom. I can't get it to adjust to the full screen. Thhis is a 29" monitor that has the control bottons instead of the nobs you can turn. It is a push button control. With the screen being so skiney I can read it to see what the on screen menu is showing to adjust the H size. Any sugestions on how to fix this?
If you disconnect the video signal, does it go back to the No Signal screen, or does it stay scrunched like that?
I'd go back over all your connectors, especially the ones to or from your remote board...
