mecha
ok, I come up with lots of oddball stuff on here, that much is obvious. my family bought a closed arcade's inventory, so there's a lot of gremlins lurking in that machinery, myself and 2 techs had to fix them all.
one problem still persists however, and it's with our Wild Riders. someone else posted a similar topic very recently, but after I've dabbled with a few different areas on it, the game still freezes. so here's my list of changes/repairs:
1) adjusted +5V and 3.3V (to 5.20 and 3.5 respectively) -- I did this because at the problem points where the game would lock up, I noticed the 3.3 would dip down to 3.25~ --- can anyone confirm that this is normal or if it will be problematic if I leave it at 3.5?
2) cooling fan wouldn't spin -- with my WD40 magic I was able to get this to work again. since the problem continued after adjusting the PSU, I figured it was heat-related. however, it still continued...
3) I removed the ROM card, and just went into the BIOS test to see if it would lock up at all. it didn't. so I powered down and reinserted the ROM card...
4) I ran the Game ROM test. IC1 and IC2 both came up with BAD messages. everything else checked out...
5) for fun, I wanted to see if this was intermittent -- the second Game ROM test resulted in all GOOD messages for every rom. (I didn't power down or change anything with the hardware itself before doing this)
6) I then played the game, and it didn't freeze up again.
so is this a matter of just poor conductivity between the ROM card and the main board? last year this same problem occurred and sometimes on power up the game would give a "GAME NOT SUPPORTED BY MAIN BOARD" error. eventually this went away, and wasn't an issue for over 13 months.
I'm running out of ideas here.
