Sega Indy 500 funky textures on the road and in the sky
pinballlooking
South Carolina
I have a Indy 500 it has funky textures on the road and in the sky. Also when you select auto or manual it has lines through the words. The wheels are kind of see through.
I has swapped boards around and the issue stays with the CPU board. Any suggestions on where to look on the CPU board?
How expensive are used CPU boards?
I had the same issue with a Daytona USA board, they tend to flake out after yeras of use as the chips tend to lift from the board. You can probably get it fixed for $150 (cost me about that when I was in Australia). Try contacting www.irepairsega.com (unless someone else her can recommend something).
