cadillacman
Hey guys im working on a deluxe sega harley davidson for a guy. THis damn things been a headscratcher butr ive finally narrowed it down..
SOmetimes it wont boot. While not booting, has 106vac( PRETTY SURE THIS IS OK AS SEGAS USE 100V TRANSFORMERS CORRECT?) into the power supply, no output..
However then the ps fires up at random when it feels like it, i do have good output( 5.2vdc, 12.2vdc) abnd it will say on untiullt he game is shut off then back to the same intermittent situation
SO what gives? bad supply i assume. I did check it over well for bad solder and found none.
Id just hack a switcher in this pig and be done, however the damn ps seems to be sega only as its huge, and has +12, +5, and +3.3 outputs and about 100 wires going to the damn thing..
SO, What are my options fellers? WHere could i find a new plug and play supply?
Is there any universal switcher otu there that has a 3.3vdc output?
Basically, in your situation what would you do? Im trying to be as easy on the pocketbook as i an to this guy.. ( he got had on this and another machine)
ps is a:
sun electronic industry
p/n 400-5330-02-91
also says jqa
thanks guys, lmk what you think.
ps is a:
p/n 400-5330-02-91
also says jqa
