ClassicEra80
Hey guys, need a sega or potentiometer expert lol. So I'm working on a sega harley davidson arcade. The issue is the the handle bars naturally sit/ fall all the way to right. Steering response is normal going left, but right turns are nothing or full tilt. I've traced it to the potentiometer in the steering housing. My question is, is the steering and volume replacement 5k potentiometers the same? I can't find the original B565 direct replacement, but Arcade Art sells a 5k Sega part # 220-5737 as a replacement. There is also the Cosmos Tocos RVQ24-series that are supposed to be sega plug n play replacements.....Happ has the 5k model #220-5373 to replace segas #220-5374 and #220-5484. Would any of these work as replacements for the steering Potento? The 1st pic below is of the original steering potentiometer, followed by the happs replacement, then arcade arts replacement, and then the original sound potentiometer in the cab. Thanks in advance for the expertise....
