Michaelthurston
Hey guys, I know you must be tired of me by now haha, but the last thing I need on this hang on machine is to fix this little issue I'm having with the sounds. I believe there is a problem with the sound PCB, but I don't know where, or what. Basically, the sounds work, but the title song is sped up to hell, and high pitched. then yous start to play, and everything with the motorcycles is fine, until you start racing for a bit, then the sound freezes...I recorded the problem for you to see, so if anyone knows what the deal is, I could really use the help.
Also, I pulled both of the sound boards to check them, and they all look immaculate. I've done the memory test, and all the roms and ram say that they're good...I've done some tests, and with the bottom board disconnected, I still get the same results...
