i have a sega gremlin astro blaster arcade and dose any one have the back door dimensions as it is missing plus the piece above the door and the top piece that is slanted
I was working on my Astro Blaster today, so I took the measurements you asked about.
Top:
24.625" H / 23.875 W
Upper Vent Panel:
3" H / 23.875 W
Four 1.25" diameter holes centered at 5", 9.5", 14.25", & 18.75", measured from left edge of panel, with each hole centered at 1.5" from top edge of panel
Upper Back Door:
22" H / 23.75 W
Lower Back Door:
19.25" H / 23.75" W
1.25" Lock Hole at 12" from left edge of panel, 0.625" from top of panel
2" H / 12" W Join Plate centered horizontally on bottom edge of panel, with 1" extending past lower edge of panel
Lower Vent Panel:
12.75" H / 23.875" W
Four 1.25" diameter holes centered at 5", 9.5", 14.25", and 18.75", measured from left edge of panel, with each hole centered at 6.5" from top of panel
All wood is 0.75" thick pressboard, painted flat black.
Hope this is useful!
