Sega G80 Pwr supply/audio amp replacement board intrerest thread
VectorLabs
Texas
I am considering making a few of these available if there is enough interest.
The board uses a standard 24pin PC power supply connector & has built in
audio amp & is compatible with most of the original Sega/Gremlin power
supply & speaker wiring. Price should be around $75 each shipped.
Vector Labs
***EDIT*** I want to make clear that this board allows you to use a standard PC switching power supply
to provide regulated +5v, +12V & -12v. The board does supply regulation for -5v and an audio amp & fuse protection.
My title of this thread may have caused confusion that this was a stand alone replacement
for the Sega/Gremlin power supply, which it is NOT, the board works in conjunction with a PC switching supply.
Once I replenish some funds I would be interested in 5. The whole power supply failure and wipe out your board thing always has me a bit worried.
I am interested in two, my Space Fury has a switcher in it not the orginal power supply. Will the mod still work?
I want to make clear that this board allows you to use a standard PC switching power supply to provide regulated +5v, +12V & -12v.
for the Sega/Gremlin power supply, which it is NOT, the board works in conjunction with a standard PC switching power supply.
I'd take one, too.
Rebuilt my power supply completely a couple of years back and it's worked fine since, but anything to protect the boards further, I'm in :) .
Jonathan
Do you have a list or partial list of which SEGA games this will and will not work with?
Will it work with all of the SEGA vector titles?
This is only intended for the Sega/Gremlin Vectors.
Mike
