MMAO - Parts: Sega G08 high voltage MMAO
Atari The Jedi
Donor 3 years: 2015, 2021, 2024
Sparks, Nevada
So I got this when I picked up a 6100 recently. Obviously this is untested and sold as is. Most likely is going to need a rebuild. I know these don't come up very often so here's your chance. It was not left outside, as I'm told but rather left in a shed so while it didn't get directly rained on or anything it got moisture from the air. I did spend some time cleaning it up for you so you can see what you're working with. All the components seem to be there. Visually the flyback looks fine (anode cup could be replaced). Hard to price these so I'm going to say MMAO
@rotormoshun was working on some G08 stuff and might need it.
Thanks, but considering the environment this has been in there is an almost unobtainable special chip on here that might not produce the 20us duty cycle needed to run the HV (yea they break). I'll have to pass on this one....
