What's the easiest way to seperate the cabs in a dual setup? I was checking the manual but there's no illustrations showing where the retention bolts are. All it says is something about the cashbox and ledge? TIA.
On Daytona the cashbox has some bolts going thru on the sides into each cabinet. There is anywhere between 2-4 or more per side inside the coin box, some are a real bitch to get to! There is a fiber optic cable which must be disconnected, DON'T lose that connector adapter! A couple of connectors on each cabinet and its ready to seperate... DOH, the marquee needs to come off too, but thats not too bad.
I remember being a real pain. I believe the screws were inside the cash box and 90 degrees. there was alot of stuff in the way. I believe I went behind the cash box to get access to the screws. atleast some of them.
It was actualy pretty easy to take apart. I only had to remove 2 bolts that were accessible through the front. I then disconnected the other wires through the back once I got the cabs seperated. I'm guessing they didn't use all the bolts they were supposed to use when they joined the 2 cabs.
