JTM
Sound is controlled within the coin tower, while waiting for a coin tower is there a temporary way to connect sound to a temporary controller? Thanks in advance!
Ill have to look at mine when I get home...can't recall if its 2 separate buttons or a single potentiometer for Volume up/down. Either way you just need to wire it up.Sound is controlled within the coin tower, while waiting for a coin tower is there a temporary way to connect sound to a temporary controller? Thanks in advance!
From the manual diagram it looks like button control. I have some spare potentiometers and my Rush is wired up to button control so I will reference that as well. Check out your setup and if not too much trouble snapping a pic will help a lot. Biggest mystery is whether it passes through anything in the coin tower or if I can just mickey mouse the wires.Ill have to look at mine when I get home...can't recall if its 2 separate buttons or a single potentiometer for Volume up/down. Either way you just need to wire it up.
Absolutely I will takes some pics when I get home from the office tonight. If it's buttons, and anything like my Initial D cabs, its super simple wiring. A couple of used control panel buttons would do the trick while you wait.From the manual diagram it looks like button control. I have some spare potentiometers and my Rush is wired up to button control so I will reference that as well. Check out your setup and if not too much trouble snapping a pic will help a lot. Biggest mystery is whether it passes through anything in the coin tower or if I can just mickey mouse the wires.
I appreciate your help.
That's what I am hoping. I'll snap a pic of my outbound harness as well.Absolutely I will takes some pics when I get home from the office tonight. If it's buttons, and anything like my Initial D cabs, its super simple wiring. A couple of used control panel buttons would do the trick while you wait.
Could I trouble you for a behind the scenes back shot so I can reference?Nice! Confirmed here:
Seller had a lot of leftovers from his vending business and with his disability it my be a minute before it's discovered in his garage. He was a good guy so I know he will put effort into finding and believes it is in there. Fingers crossedCould I trouble you for a behind the scenes back shot so I can reference?
Like this?Could I trouble you for a behind the scenes back shot so I can reference?
Hell yah! Good to hear!worked like a charm. By removing the sound wires from the connector and soldering to a couple 5k pots I can control my sound in each cabinet. Thanks for the help!
