Sega Blast City Monitor
muggsy
Auckland, Melbourne
Hi All,
I have an issue with my Blast City Monitor. It's a MS-2930. The problem happened after I rotated the monitor from horz to Vert.. and then back again after a few days. The problem appears to be with the remote board. All the correction dials work fine (and respond) except for the Horizontal size. The dial works but nothing responds. I'm kinda stuck as to what to do. Anyone have any suggestions?
Cheers
Ok, So I had the remote board checked out and my monitor guy reckons its working OK.. so much be something up with the Chassis after I moved it :(
Did you or him reflow some solder where the remote board connects to the chassis itself? I would also make sure that I have good continuity going through wires and the connector itself.
ahaha that's too complicated for me. I just removed the remote board and had him check it over. The pot seems to working correctly. I'm pulling the tube and chassis and will drop it around. He reckons it might be a dry solder joint and the movement of rotating to vert and back again might have loosened something
