NipRing
So ive got a Sega Blast City cab with a Nanao ms2931 tri-sync monitor. Never had any problems before. While helping a friend trouble shoot his same cab via texting, i had unplugged the 15 pin plug that goes to the chassis to count the pins and verify it as indeed 15 pin. Anyway i did this with the cab off of course, and plugged it back to the chassis. 10 min later i went to turn on my cab and everything turns on but the monitor. Its like it has no power. Usually there is a static feeling when i touch the tube, but now there is nothing. I've checked to make sure i didnt bend any if the pins in the one connector I plugged/unplugged and that it is seated well. But no luck. What the heck could have happened? I do have a spare chassis and i did swap out the two fuses but no luck. Anyone live close to Waukesha?
Also, I've never worked on any monitor before..so yeah...
