The control stick is completely dead, no control of the plane. Vibration mechanism is working though. The rest of the game works. Is this a common problem with the Afterburner games, any ideas on a fix? Where and how to start?
Also, press TEST MODE button, select INPUT TEST and press TEST again.
What do the inputs read? All 00H? Including the throttle? ("Slottle" as sega says!)
...These gimbals have potentiometers which have a signal wire, 5 volt wire and a ground wire connected to them. I assume it is a similar mechanism in the Afterburner game.
