"Seems like an easy fix."
Atleast it is priced accordingly!
I tell you what, the 100% non working effed up, some dummy already tried to work on it, stuff priced like 3x a mint one makes you just wanna reach out and slap a bitch! When they say, probably an easy fix, wire or fuse or something! Stab stab stab stab!!!! Muwhahahahahah
i've never owned one but if it really is only the trigger not working, that would have to be either a loose connection or bad switch, right?
This one does sound easy. As mentioned, probably a loose wire or bad switch. However "sounds like an easy fix" usually means "strip out and rebuild from the ground up".
I should cut the guy some slack......and consider him honest....
He's only asking 50 bones and "Seems like an easy fix." is usually used to justify an outright silly price.
So sorry Operation Wolf...."I Am Just Not That Into You"
:cool:
