Seeburg Neon Test Lamp
jboettc208
Minnesota
Hi there!
Can anyone tell me where I can pick up a Seeburg Neon Test Lamp or what to use in place of it? I read on another site to use a Neon #51 in series with a 330k resistor but can not find one. Any help would be great! I am working on a Seeburg LPC 480. It has the scans twice but plays nothing issue.
Thanks!
All that "test light" is a common neon light voltage tester available in the electrical section of any hardware store or even Harbor Freight Tools. They only cost a couple of bucks. They test voltages from approximately 90 volts to 300 volts AC or DC.
Seeburg just wanted you to buy theirs because it was stamped with the Seeburg name on it.
Attached is a picture of the test light from the hardware store that you can use.
I bought the parts from Mouser to make, but never did. I have that same tester also.. now I guess I'll have a few neon lamps on the shelf if I ever get to work on my juke..
Thanks! That worked perfect! I now have the problem narrowed down to the carriage RO circuit.
