Seeburg M100C
jukebox10
Clyde, North Carolina
Having a little problem with my C. When you put the coin and select a record to play the flywheel turns but no action, motor will run continuously. I have scanned the carriage to k9-k10 record space, left it in scan and did the adjustment on the adjusting screw, but it still doing the same. If I manually flip the trip mechanism it will play the record selected and if other selections are made it will usually play them, but if your dime runs out and you have to put more money in, the flywheel will turn and will not select the record until you manually trip it. Not sure whether were to go from here?
