Seeburg 3w1 table top trouble, how many Amps?
RadioJoe
New York
Need some background info on the 25v transformer on WRS5-L6 selector board that provides power to the Seeburg 3W-1 table top selector. Anyone know how many amps this transformer, T2, needs to provide? I get 28 volts but only 4.7 amps. The problem is my 3W1 seems to not be getting enough "juice" to make the motor rotate fast enough, engage the spring loaded gear, and make enough torque to rotate gears through the cycle. The rest of the board works great. Relays work and ratcheting takes place on board. 2050 tube is pulsing. The problem is the motor in the 3w1 is to weak to push the gears and go through the cycling. Any pointers? what to look for? do I need a new motor or transformer?
The kicker is I cant find anything wrong with the transformer! It ohms out good and no short to ground on either end. So, help? Maybe?
