SEE PHOTOS...Is this monitor easy to change to a Vertical Orientation?
ValentiSports
Rochester, New York
Hello,
Please let me know if this would be an easy orientation change from horizontal to vertical. I can post different photos if these are not helpful.
THANKS
Probably not with that frame, unless you build a custom wood frame for it.
BUT - measure the width from inside wall to inside wall. Then measure the length of those bars attached to the monitor. If the length is the same, pull it out, rotate it 90 degrees, and slide it back in...
