"Secret" spy pix from the Yestercades store room ...
pcjohn
Games currently being restored. All are more or less
working but the previous owner didn't own a vacuum
or any form of liquid cleaners.
They should all be up on the main floor in a couple off weeks.
JD
PS - The one pin in the corner is a Hook, this one was shopped and will be
used to fill in other pins that are going to be pulled and shopped.
JD
Why does that APB just have one bulb in the center of the marquee? There isn't supposed to be a bulb in the center. :confused:
I'm presuming the socket is in the wrong place. The previous owner
put absolutely no money into the maintenance of his games. The wiring
on the Space Invaders pin is a nightmare. It has the wrong power supply board
and they hacked the hell out of the harness to accommodate it (lots and lots
of wire nuts).
The APB is actually the best condition of all four machines. Just 30 years of
dust in it.
Outrun needs a cap kit and a bearing for the steering wheel.
Crystal Castles needs a trackball rebuild and a couple new Ram chips
on the board (the old lines through the sprites trick).
Of course all the Atari games will get new Big Blue Caps just as I've
done to all the other games on the main floor.
JD
