scrolling display on cirqus voltaire...what should i check?
Klassic
Boynton Beach, Florida
i have already replaced the display with a known good one, and exact same issue...
so i'm probably looking at an issue with the audio/video board. any caps i should replace that can cause this? any DMM reading i should be taking off that board? i've never encountered a scroller before.
http://www.youtube.com/v/dauPc7PaLXA
sorry for background in video, son and i were watching family guy.
cold solder on dmd controller? i just figured out i need to rebuild the high voltage section of my dmd controller for fish tales,
so i would check your dmd controller
One or more caps on the A/V board most likely are bad. Here's a good source for caps. http://www.greatplainselectronics.com/
cold solder on dmd controller? i just figured out i need to rebuild the high voltage section of my dmd controller for fish tales, so i would check your dmd controller
sweet. yep, the caps "look" fine, not sure of what numbers i need to look for if i ohm'd them out...but 1 is a little loose, so i'll probably reflow the board to start with.
