Screws
MrHiu2
Holt, Michigan
What sort of tool or screw driver do you need to remove the screws from a Bally MCR cabinet? The light bulbs are going bad, so I figured I should replace them. They look almost like Hex-screws, but they have a small bit in the center of them. None of my screw drivers seem to work.
Tamperproof Torx T-20 bit. These are quite common in the Harbor Freight bit sets as mentioned by other persons.
I had to get a set for my Elvira pinball machine for the header. I have the ones you set into a socket set as well as one that comes in a retractable screwdriver set. Both are handy for different situations. Check out your local hardware store.
