I found out that I had 2 of the sync wires backward on my monitor, now I can see a good looking colorful birght picture, Now the top 1 or 2 inches of the screen pulles to the left, any ideas??? WG K7000 monitor. . . .
Well then, if he had "2 of the sync wires backward" like he said, then he needs to disconnect one. MK2 is JAMMA, and K7000 doesn't like the composite negative sync on the negative vert pin. That pay be causing part or all of his issue...
I don't think it's even mentioned in the schematics. Lemme go look...
Ah, here it is. In the horizontal hold adjustments, it has this:
A little ambiguous to newbies, as it doesn't say NOT to connect the vertical, but I've found that hooking up the vertical can cause display issues, and had it verified elsewhere besides the manual....
