cool, no new holes in the cab.
Peace
Buffett
Peace
Buffett
ok, i would turn down your +5 on the PCB to between 5.5 to 5.1 when it hits the bottom and call it good.
as for the chassis, you may need to send it in if you cannot figure it out, i can look over it to see if i find any issues.
it could also not have a problem with any other game but your MK board.
i have see this before and when the chassis was swapped out, the game ran fine.
i put the other chassis in another game and it ran fine.
i know some CAPCOM games have this same issue, they would play fine with some K7000's and not others even tho there was nothing wrong with the chassis.
this may also be your case.
you will need another K7000 to see if the problem stays or follows the current chassis.
if it fixes your issue, i would just leave it as is and use the other chassis as a backup or for another game.
Peace
Buffett
I think this is an issue with the midway stuff and k7000s. I just put together a k7000 for a NBA maximum hangtime. It was missing the whole monitor. When I run the NBA board it has a slight jitter left to right to it also. When I throw my 4 player xmen board in the cab there are no issues at all. I just capped and Fly'dthe chassis. I have another couple of k7000 so I will swap those in and see if any of them are better. Does you k7000 have the little satalite board attached to it? Mine does, wondering if that has something to do with it. Post up a pic of your chassis. Here are a few videos I shot of the jitter, I'm not sure it shows up well but worth a try. Does yours look like this?
https://youtu.be/9-8Y9D-CRlk
https://youtu.be/OztvKV9KSGU
https://youtu.be/X06E3Q8Ktm4
https://youtu.be/YDq4k2j0ksE
