Scorpion or Blackout help needed
wildwest3163
Lake City, Florida
I need someone who has one of these to take a look at it for me. Specifically, I need to know where the black and red wires off the GI relay run to. The GI relay is the little square box mounted on the bottom of the backbox right in front of the large capacitor, has 2 yellow, 1 red and 1 black wires coming off the top. Both my Scorpion and Blackout are missing the wires and my other system 6 games dont use the GI relay
I can look at and take a picture of my scorpion at my work. If you like. But I would also consult the manual its listed in there.
If you didn't get sorted on this...
On my Blackout:
The left wire is BROWN/VIOLET, right wire is RED.
BROWN/VIOLET goes to connector 2J9, pin 5 on the driver board (Solenoid 15 Flash Lamps)
RED goes to connector 3J3, pin 6 on the power board (Solenoid B+)
If you haven't already found them, you can see how this is wired up on the "Solenoid Wiring Diagram" document at firepowerpinball.com
