Picked up a Prop Cycle (posted about it here which has a 50" Mitsubishi VS-5042 consumer tv. The number one problem is the picture goes out sometimes. Sometimes it never shows up when I power on. Sometimes I'll see a picture for a few seconds and then it goes out. Other times it'll work fine for a long time, with maybe a few minor flickers sprinkled in here and there as though it was about to go out but then recovered. When I've seen it go out, it seems to collapse to the center of the screen and then the screen is totally black. Is this something that will likely be taken care of by replacing electrolytics and/or fixing cold solder joints? Sound still works when this problem happens, btw.
It also doesn't have great convergence around the edges (I've converged the center of the screen via the menu). How hard is it to deal with this in a projection tv?
It does have a fair amount of screen burn, unsurprisingly. So ultimately if I come across a cheap enough, ideal enough tv on CL that might be my best option. But for now I'd like to proceed with repair.
I know this is pretty general info at this point but I'm hoping to just get a sense for how bad of a job I'm in store for and if I'm likely on the right track with the shutdown problem or if there's other stuff I need to look for.
And I am aware of the need to clean inside the TV too. Hopefully between cleaning and rejuving (if necessary) I'll be convinced that the TV is worth saving!
