School me on Playchoice gun against a vs gun
flex
Donor 7 years: 2019-2025
I hear that they have different connectors? Do they look differently, or one doesn't work in the other harness? I have a vs. hogans alley that the gun works 90 % of the time. I just capped the monitor and cleaned everything. The B+ is a perfect 108. I have other guns that plug in, but they don't work at all. The gun that is on it appears to be a happ, and the one connector has a ground wire looped in two of the holes. The other guns I have do not, but they fit. I also heard that a faulty ground wire can cause gun issues. Gun games are my nemesis and I have trouble keeping them working. ANy advice or hints are greatly appreciated.
We've gone through this a few times in the past. Yes, you can swap them between VS and PC. The connectors are the same, but the colors of the wines are different. The white/blue/yellow to white/blue/purple is pretty easy. But, the other connector matches brown to pink instead of matching the colors. I have both kinds of systems and both kinds of guns, and swap them out.
And yes, gun games are a HUGE pain in the butt!
Let me understand the wire colors, they are plug and play or you need to swap some wires to make they work?
