School me on coin switches
Shavenyak
Donor 2023
Sarasota, Florida
I'm looking for a couple of these. One for Spy Hunter and one for my Taxi pinball. They appear to use the same switch. I need the kind that have the mounting holes in the top right and bottom left corners. Looking for these presents many options and I want to make sure I get the right kind. I think what I've found at Happs will work. Here's a link:
http://na.suzohapp.com/accessories/42010500.htm
I'm looking at the 1351 and the 42-3779-00. The difference between the two appears to have to do with amps. Which should I use for my coin doors? Also, what does terminal size mean and anyone know where to find the screws to mount these?
For a coinswitch the current rating isn't going to matter as it is going to be so miniscule to begin with.
These are straight switches though. Normally you should be able to find the switches to match your door with the wire already pre-formed to the correct dimensions.
