FS Parts: Save $120 on NEW Force Feedback Motor! and more!!
I just converted a Cruis'n to Fast & Furious Drift. The Cruis'n had a 90v motor. FFD uses a 36v motor. So my guess is it won't work in Cruis'n, since I had to swap the 90v motor. I thought I read somewhere that Cruis'n used a 36v motor, but that's not what was in mine.
The motor will work in any driving game the uses a 36v motor. It looks like it doesn't come with a connector, so you'll have to add that as well.
If anyone needs a 90v motor, I have one for sale from the Cruis'n I converted. $25+shipping.
I can't find anything definitive on Cruis'n USA motor voltage. The cab I converted had a 90v motor. But on Happs website it shows a steering assembly that's compatible with with a lot of drivers, including Fast & Furious Drift and Cruis'n Sit Down. I know FFD uses a 36v motor. So that would lead me to believe Cruis'n does also, if the same assembly on Happs sight is compatible with both. I've only worked on a couple of these sit downs, so I'm far from an expert.
I also noticed that there was an adapter in line with the 90v motor that has a sticker that said "HOT". Maybe this was some type of converter for the 90v motor? I didn't use it, since the FFD kit has the 36v motor plugging straight to the FFB board.
anyway, the motor on Betson looks like a good deal if you can use it. I'm prob gonna buy a shifter, just to have one as a backup. From the research I did, I believe it will work with any driver. If not, the parts on it alone are worth the $.
