Can anyone locate an actual schematic of that SUPER CPU pcb showing those components that burned? I'm curious what they are and what they are doing with the 12V.
Looks like a pair of zener diodes and a resistor, sort of... right?
If not, what?
The larger green thing that burnt up is an inductor.
http://www.mouser.com/ProductDetail/Vishay/IR04EB100K/?qs=tckYUfRMGW4JRqQTGPDQrA==
The other two things are ceramic capacitors. They'll be fine. They are covered in soot from the burning inductor. That'll clean right off.
Edward
The short circuit has drawn too much current through that inductor. The inductor heated up and burned from the excessive amounts of power being pulled through it.
It's not an uncommon sight.
