Satan's Hollow Power Brick FUSES
webdoc90
Donor 2012, 2025
Simpsonville, South Carolina
I'm just fixing up my Satan's Hollow. I'm trying to get the Blacklight working. It keeps blowing fuses in the right most fuse location. The ones that you need to twist in. Current in the two most ones on the right I have a 20 amp slow blow and the one that controls the lights is 2 amp regular. When I bought the game it came with these. I suspect these are NOT the correct sizes. Can anyone tell me the correct sizes?
The fuse closest to the oil cap is a 4 amp slow blow. The other fuse is a 2 amp regular blow.
If your light fixture keeps blowing fuses, it's probably got a bad ballast.
Edward
Thanks for the fuse information. I knew the 20 amp didn't seems right. That was my next thing to try since my super pac had the same problem. I'll keep you posted.
