Satans Hollow monitor won't power up
Shavenyak
Donor 2023
Sarasota, Florida
My SH works fine except the monitor won't power up. I've had the monitor chassis tested so I know it's not that. One thing I'm confused about though is that I'm getting 130 volts on the power plug that goes from the cabinet to the monitor chassis. All fuses in the bottom of the cabinet test fine. Not sure where to go from here. Any suggestions?
That's very strange...just for shits and giggles pull another game close enough to use it's power plug and see if it fires up. If it works then I would say you have a bad ISO.
